ORIGINAL: acdii
As a test I put an inline 20 amp fuse in, and as soon as I started to turn over the DLE20, it blew the fuse. These do draw some current!
The starters are designed for 12 volts. When we start adding more voltage you can over heat the starter if you keep rolling over a motor that doesn't want to start. I have used two auto batteries set up in series for 24 volts on a cheap stock starter and it really rolled over the Zinoah 45 but you didn't want to be rolling over the engine for a long time or your starter welded the switch and could over heat and burn it up.
When you change over to the 18 volts you want to roll over your small engines by hand and make sure they aren't flooded or you can break a crank or rod if the engine is locked up.
The HF battery is great but when charging you want to make sure you don't go over that five hours. The charger will cook the batteries if left on too long!!!!
