RCU Forums - View Single Post - How to install a kill switch in a 6ch setup that uses already a dual elevator???
Old 05-26-2012 | 06:04 PM
Charlie P.'s Avatar
Charlie P.
Default RE: How to install a kill switch in a 6ch setup that uses already a dual elevator???
You can also use a Smart-Fly servo combiner("Equalizer II") for the elevator halves from one receiver jack. I prefer these to mixing from the Tx. They are easy to get right and matched. Ihave used these to match two servos to a rudder (both push/pull with rod linkage)and they are able to completely eliminate binding of the two servos on one control surface.
http://www.smart-fly.com/products/Eq.../equalizer.htm
