Pretty sure this was all I needed. You may have to shim up the control arm to c hub pins a little to make it work.
103360 | FRONT AXLE 5x26mm (2pcs) | <form method="post" action="http://www.hpiracing.com/mm5/merchant.mvc?"> <input size="4" name="Quantity" value="1" type="text" /><input border="0" alt="Update" src="/mm5/graphics/updatebskqty.gif" type="image" /> | </form> $8.00 | $8.00 |
<form method="post" action="http://www.hpiracing.com/mm5/merchant.mvc?"> <input border="0" alt="Remove" src="/mm5/graphics/remove.gif" type="image" /> | </form> 103362 | LOCKING HEX WHEEL HUB 12mm (4pcs) | <form method="post" action="http://www.hpiracing.com/mm5/merchant.mvc?"> <input size="4" name="Quantity" value="1" type="text" /><input border="0" alt="Update" src="/mm5/graphics/updatebskqty.gif" type="image" /> | </form> $8.00 | $8.00 |
<form method="post" action="http://www.hpiracing.com/mm5/merchant.mvc?"> <input border="0" alt="Remove" src="/mm5/graphics/remove.gif" type="image" /> | </form> 100311 | FRONT UPRIGHT SET | <form method="post" action="http://www.hpiracing.com/mm5/merchant.mvc?"> <input size="4" name="Quantity" value="1" type="text" /><input border="0" alt="Update" src="/mm5/graphics/updatebskqty.gif" type="image" /> | </form> $10.00 | $10.00 |
| | Total: | $26.00 |
| | Total: | $26.00 |
ORIGINAL: volcanoman01
this is to billymare I would appreciate it if you could give me the part # for the c hubs and steering arm you used on your twister xtg pro .THANKS
