ORIGINAL: tgwhitley
David
Do you have copy of the Exception/Deception RE plans? Might get some ideas from that drawing also.
Tim
<br type=''_moz'' />
Tim,
There were no published Exception plans - that is, with a RE setup. The photo pretty much says it all though except for a possible pipe floor and modified FW. You might be interested in following Kevin's "ground up" build on RCG. He's basically building a wood Exception fuse with foam core surfaces.
The Deception plans I can email you - I should have your address at home.
David
