RE: Brison runs rough/hot crankcase?
I would check the crankshaft as already suggested plus the bearings are usualy damaged on an impact and this will cause the case to get hot as well, and a damaged bearing seal will lean the engine out too.
Most of the time it is usualy the bearings and not the crank but ..........
