RCU Forums - View Single Post - Tamiya Wild One is Back!!! (in Stock!)
Old 07-06-2012, 02:53 AM
banzaihobby
Default Tamiya Wild One is Back!!! (in Stock!)
The Wild One was originally released in 1985. 2012 marks the year it has been re-released to hobbyists who missed the kit the first time around.
Specs and Features
    [*]Scale: 1/10 scale[*]Construction type: assembly kit[*]Terrain use: off-road[*]Drive-train: 2WD[*]Drive type: gearbox[*]Drive line: dog bone[*]Differential type: gear[*]Suspension: fully independent double wishbone[*]Steering mechanism: bell-crank[*]Shock damper: oil-filled damper[*]Shock damper material: aluminum[*]Tire type: rubber[*]Tire tread: pin spike[*]Body material: Clear Polycarbonate[*]ESC NOT INCLUDED[*]ESC type: NOT INCLUDED[*]LED Light buckets: no[*]LED lights: no[*]Motor type: 540-brushed type[*]Bearings: shielded ball bearing[*]Chassis material: FRP[*]Sticker material: vinyl[*]Internal gear ratio: N/A[*]Adjustable camber: fixed[*]Adjustable toe angles: front only[*]Adjustable ride height: yes[*]Adjustable gear ratio: n/a[*]Adjustable wheelbase: fixed[*]Adjustable track width: fixed[*]Adjustable shock angle: fixed[*]Anti-squat adjustment: n/a[*]Droop adjustment: n/a[*]Special features: 1150 size bearings included x8[*]Requires: 7.2 battery, charger[*]Requires: polycarbonate paint[*]Requires: radio gear[*]
    Live your childhood dream and don't miss opportunity to purchase Tamiya 58525 Wild One Off-Roader
    [/list]
