I don't know what you're using for these calculations, but, just because something is in the calculations, doesn't mean that it is correct. I suggest that you get the best possible set of equations and do a hand calculation to see if the results you are getting, are close to correct. If you read through the discussion on determining the neutral point , at
www.rcaeronauts.com, you will get an idea of what I mean. Good luck.
