ORIGINAL: PatternFlyer
I've had couple of 20c packs that came out over 140 degrees (balloon like).
How do you cool them down? I've seen some Japanese using PC Fans to cool the motor/esc when plane is on the ground.
Ihncheol
Bob Violet sells a piece of aluminum that you rest the packs on to wick the heat out so something along those lines. putting the pack in a ziploc bag then into a shollow bucket of water would probabley be effective too. I shorten my flights, as mentioned above
