RE: Max Fuel Tank Size?
Actually its the length that is the problem. Flying straight up on a nearly empty tank will be the leanest part of a typical run. The larger tanks are usually longer and will make this worse. Uniflow tank setup will not improve this, if you need a larger tank recommend a pump or regulator.
