RE: Aurora 9 HTS telemetry not working
I have the same problems with my new HTS telemetry module while using my Optima 9 receivers. Only the battery icon is available on the sensor screen. Once in a while, the cockpit view is there but none of the sensors are showing numbers. I've called Hitech and tried everything they suggested including switching the red & yellow wire positions in the plug and that actually made things worse because not even the battery voltage showed up on my display. I even bought another telemetry module without any better results. Since I'm not using the SPC ports, I'm assuming that both should have jumpers in them? The only difference I see in he pictures posted is that I'm not using SPC. Now this same HTS-SS telemetry system works fine with my Optima 7 and it hasn't been updated since last year. Both of my Optima 9s, my transceiver module and transmitter have had their firware updated. Any suggestions would be appreciated.
