RCU Forums - View Single Post - CDI gr8flyer55
Old 08-17-2012 | 07:03 AM
  #232
nyemi
Default RE: CDI gr8flyer55
Hi Jake
<span lang="en" id="result_box"><span class="hps">Thank you for your</span> <span class="hps">response.</span>
<span class="hps">I</span> <span class="hps">suggest</span><span>:</span> <span class="hps">your</span> <span class="hps">code</span> <span class="hps">works</span> <span class="hps">well for</span> <span class="hps">low</span> <span class="hps">RPM</span> <span class="hps">operation.</span>
<span class="hps">Due to</span> <span class="hps">the manual</span> <span class="hps">start</span><span>.
</span></span><span lang="en" id="result_box" class="short_text"><span class="hps">Minimum</span> <span class="hps">manage</span> <span class="hps">200RPM</span><span>,</span> <span class="hps">the ignition</span> <span class="hps">timing.
</span></span><div id="gt-res-content" class="almost_half_cell"><div dir="ltr" style="zoom:1"><span lang="en" id="result_box" class="short_text"><span class="hps">I wish</span> <span class="hps">good work</span><span>.</span></span></div></div>
