Originally posted by TotlKaos
Make sure you have the acceleration and rudder mixes disabled! almost sounds like you have a mix in there that is causing problems.
Make sure that the boom supports are in the bottom holes .. I had problems with my Freya when the boom supports were in the holes that were recommended in the Manual.
Make sure that you are the proper distance out on your servo arm and not short or longer that what is recommended in the manual.
REVO-MIX is definatly off. He assigned it to a separate switch to confirm that.
Boom supports are on the bottom holes.
He used the same hole on the servo-arm as i did on my Sceadu. I don't remember the figures, but when i set mine up, the outer hole on a standard 4-armed servo-arm would agree with the manuals recomendations.
