RE: Windex method real or not
I have used the windex method for years with Monokote . I spray on the windex and apply the trim , squeegeed out the excess and allow to set for at least 48 hours . I then very slowly and gently go over the trim with a socked sealing iron on low to set the adhesive( only warm enough to seal but not shrink). I then go around the edges with trim solvent to be sure the edges are sealed
