Has anyone used the SD-10G with RealFlight 6?
I have the cables and it is "partially" working, but I'm getting really strange behavior such as the 1st and 2nd channel getting input from one channel from the radio. In other words, I use elevator up and it controls the ailerons too.. also, every channel "glitches" every now and then. I've verified that the channels are set up correctly in the SD-10G.
I'm using the RealFlight mode that is suppose to let you use one radio setup for all planes. I haven't tried using the "raw" mode yet, but that's next on my list. I was hoping someone had been through this and new the "trick" to getting it going.
Russ
