RCU Forums - View Single Post - thunder tiger reversing y harness??
Old 08-26-2012, 04:23 AM
ReaperGN
ReaperGN's Avatar
Default RE: thunder tiger reversing y harness??
Then your not doing it right. Flipping the servo or the arm will reverse the direction of the movement. If the servo is mounted to the axle then automatically it should be reversed when you install one on the rear axle. Buy simply flipping the servo horn around you can see that it changes the travel direction.
