ORIGINAL: BillinIndiana
So if I use CA on say gluing two 1/4 x 1/4 sticks together for the spar doublers... Would you cover the entire 1/4 width of the edge to be glued or just a thin line down the center?
Thin CA should run by itself so just hold the two pieces together and run the CA along the seam. You could do both top and bottom seam to be sure.
