RCU Forums - View Single Post - Has anyone used the SD-10G with RealFlight 6?
Old 08-28-2012, 09:00 AM
FarrellF
Default RE: Has anyone used the SD-10G with RealFlight 6?
I have not used the SD-10G with RealFlight but I have used it with Phoenix. It works fine with Phoenix. Just set modulation to PPM8 and plug it in...
If you did not get the flight sim adapter from Airtronics you might want to check that it was wired correctly. It should be wired like this:
-Farrell
