RE: durafly se5a power drain
Try reprogramming the controller. When you do, remember to set the throttle trim down. Also, if you have another ESC give it a try (swap them). It could be the motor. If it gets hot or in a crash it can be damaged. If you get the same results with a different (same specs) ESC I'd say your motor is bad.
