RE: Nose hunts to the right?
I'll check it out in rate mode then. But if I'm understanding you, it's that I don't have a good enough gyro and possibly not a good enough tail servo? It wags pretty hard if I go above 85% gain, so I know i'm not getting all of the good out of my gyro. It really did help with adding in some rudder trim on the transmitter but if that will cause other problems as I start doing aerobatics I'd rather fix it right at this point.
