RE: Reaction 54 Jet Kit
hi Bruce,
the retracts and struts are Pro-link from Intairco, extended well wheel out 15mm, made a new retract base from aircraft 5 ply, pics on posts #2976 #2983 #2985 #2988. simple mods, fitted the 3/4 triangle as per your plans. will add more pics to this post. Jet- Tronics valves run the retracts and brakes. Elevator to be fitted. decals to be stuck on, work in progress. Jet Cat will power it. JR 11x TX with a 12RX. Hitec servos as per build manual. afterburner fitted. Fitting the turbine will be final challenge.
cheers Grant
