RCU Forums - View Single Post - Need help with Covering issue
Old 08-31-2012 | 07:06 PM
LonnieMcc
Default Need help with Covering issue
Hey guys, I hope this is a good area for this post.
I REALLY need some help with my covering job I am doing. Let me being with some of the details.
I am covering a CG Chippy and trying my best to do the Art color pattern in a way. First off the wing is covered entirely in ECONOKOTE white. The trim is being done with transparent Red and Blue Monokote.
Reason I am using this setup, is because I don't have a whole lot of $$ I can spend right now on covering. The LHS had a good deal on the Econo stuff, so I used it.
I was able to do the blue on the underside of the wing using both the Windex method and one section without Windex. So far both "look" like it is sealed. Only thing is, when I was trimming the blue, some of it started to come up.
I tried searching thru some post on here to find ways to control that, but never found anything on Mono over Econo.
So question is this. What can I do to make this work. I really don't want to have to strip the entire wing and start over.
