I am using a trailing link, but unfortunately the wheel is not offset enough to fully retract. Even with a couple washers under the front of the retract, it still sticks out.
ORIGINAL: Xairflyer
I Like it, the one in the kit is not deep enough for the wheel.
If you use a trailing link leg it will fully go i to the fuselage without and mods to the retract mounts.
