RCU Forums - View Single Post - Problem with 2.4gz radio. PLEASE help
Old 09-10-2012, 07:34 PM
opwan
Default RE: Problem with 2.4gz radio. PLEASE help
Re-bind, turn off the ESC and take the bind plug out, see if that works. Oh and reprogram you throttle settings also.
ORIGINAL: dustint209
I am having a problem with my remote. It's a HK-GT2 from hobby king. I have binded the radio and receiver with no problem. But When I switch the car on than turn the remote on the steering works fine but the motor does not register. If I pull the trigger slightly the motor beeps to confirm connection than the motor runs at full speed. If I pull the trigger forward the motor stops but as soon as the trigger goes back to center it starts spinning again. I tried to adjust the throttle trim but I cant get it to stop spinning with the trigger in neutral position. I tried with another remote and everything worked fine with no problem. What should I try? Is the radio no more good?
