ORIGINAL: Bozarth
Bill,
The sim games can mess you up - for airplanes, pulling the stick back towards your chest is the standard to make the plane climb. Hold it there long enough and the plane will loop (assuming it has enough power).
Pushing the throttle stick foward adds power - as if you were stepping on the gas.
Kurt
Yep thats the way this XBOX RC-Sim is.. That's what I meant by "Up is Down" you push up on the right analog stick of the XBOX controller and the plane goes down and vice versa... The left analog stick is the throttle "Up is more gas" which I guess also makes the XBOX controller an Mode 2.
