RE: Codbuster help PLEASE.
Have you tried tightening the front servo saver all the way to test whether it's causing the problem? Also be sure that the steering rods running from the center servo horn/wheel are the correct length. The holes in the horn/wheel should point straight to the sides of the truck when the servo is centered.
