RE: Mamba monster truggy elec problem
I don't think it's the low voltage cutoff, it does this at full charge. I've read in some posts it's been bad batteries most of the time. I am running a turnigy 4s 5000 mah 40-50c, it just kind of hesitated sometimes it seems like. The low voltage works good cuz it only gives you a burst of speed every time you punch the throttle that part is working fine. It flys when it's accelerating hard, and I don't even have the esc tuned right up, when you do get cogging what is the solution? Is it gear it down or up?
