ORIGINAL: PlatinumZJ5.9
Does anyone make a bolt up kit using the stock axles and frame but using longer arms to extend the wheel base a little bit?
You mean with stockish plastic arms? I don't know of anything like that. You'd probably have to use a 4 link setup, which would require some modifications to the axle.
