RE: 12FG Tx radio problem
I don't understand why the default setting would be less than 100% when the throttle stick is moved to the full up position? When I move the throttle stick to the full WOT position the vertical line that moves in the graph I would think would move all the way to the right on the graph, but it doesn't. IT only moves to just past the halfway point.
Is it possible that I set up another model in the Tx in a "GROUP" setting that has now made the above condition standard for all my models?
Could you please explain how I should change my Throttle curve values to see if I can get full WOT.
Mike
