RE: ESM BF-110C ZERSTORER 95
I longated the the hole in the firewall to get the fuel tank to set more level.. preparing to install Hitec 475 for the airlons.. not much going in the fueselage other than the standard servo with a 4/40 plastic sleeved steel pushrod for the tail wheel.. instaled a spring shock on the tail wheel, and attached the assembled stablizer to the fuselage with a small machine screw and a tee nut attached to the fuselage..
