RCU Forums - View Single Post - STRETCHING A HULL...IS IT POSSIBLE ??? Old Graupner Systems Cat build
Old 09-30-2012, 03:05 AM
  #58
colosus
colosus's Avatar
Default RE: STRETCHING A HULL...IS IT POSSIBLE ??? Old Graupner Systems Cat build
nobody got any more ideas...???
Well here goes a little pic i modified...its of the Mystic C5000...the reason is because i have plans for the wooden Lithium Cat and Mystic, this is just to show you that it can easily be modified, all i did was remove the new type transom and lifted the sides...
When i come to build it i will show how i will modify it..the frame must be modded first..
It just shows that it maybe possible to mod a newer version hull into an older version...but with higher speeds...from the newer tunnel and design..this will be a great project..
Here is my new type Reporter Cat..it should look like this
