ORIGINAL: hsukaria
Even though the kit implementation is different than the ARF, you could buy the kit plans from SIG and rebuild the fuse. Heck, if you get re-imbursed with a kit from SIG, you can use the plans from the kit and re-build your ARF fuse as well. You will end up with 2 4*'s, double the fun!!!
That is EXACTLY what I plan to do!
BTW, any one have issues posting after using caps? What I typed exactly in caps, my cursor jumped to the beginning of the sentence, and when I moved it to the end, all text disappeared, then reappeared with my cursor back at the beginning. Happened a couple times now.
