RE: ESM BF-110C ZERSTORER 95
Got the fuel lines in. Nothing fancy on the prop or spinner... Using a 3" Du-bro spinner opened up the prop slots about 1/8", if I were using something scale I would go with a 3.25" or 3.5" spinner... For the prop I am using a Master Air Screw three blade 15x7", it should be close enogh to get me started.
Note- If I had known, Iwould have disregarded the center line marks on the firewall from the factory for engine mounting, it is about 1/8" low to line up with the cowl properly.
