ORIGINAL: rcwarbirdbuilder
Kahlog, where did you set the balance point on yours, how far back from the leading edge at where the wing mates with the fuselage?.
The CG used by the electric conversion done on rcgroups for MAN was 147mm back from the leading edge of the wing along the fuse. I set mine slightly forward of that about 135mm. The manual states 85mm, but thats waaaaaaaaaaaaaaay nose heavy
