RE: Transmitter problem possibly?
Do you have the manual for the radio? If you do, you might want to go through it and make sure your radio matches what your heli is doing and set up properly. If your heli and sim do the exact same thing when you try and fly them, then it has to be the setup in your radio. Never fly the heli unless you are absolutely sure when you move the aileron right the swash moves right, when you move the elevator forward the swash moves forward, etc. Is your radio mode 1 or mode 2, mode 2 being the rudder, throttle and pitch are on the left stick?
Personally, it sounds to me that your swash is not setup correctly so if you try to push a little forward elevator the left aileron is moving instead. I think it's on page 13 of the manual it has the swash setup, and I think it should be set to 3-S.
I'm just throwing some stuff out there.
