RE: AR-6 Construction Thread
Select several of the heavier balsa sheets and use them for the top sheeting.
I try to use the heaviest wood on the left hand side of the wing. This helps counterbalance the engine weight.
Place a sheet of wood at the front and back of the skin template. A third piece of wood is fitted to go between the front and back pieces.
The sheets are taped together at the seams with masking tape.
