RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Those are impressive numbers Rev! There's no doubt APC props make thrust. That is why they seem to be the most popular prop in use worldwide.
Dan, I like that little check valve! But in further thinking I realize it would not be appropriate for use on the FS400 with the RIM manifold as the crankcase needs to be closed during operation.
