ORIGINAL: trooper1954
Thanks SpeedDemon...throttle is indeed the left stick, but digital readout at top left of screen on transmitter reads "Mode 1"? Not sure how or if I need to change this somehow?..Also, there are 4 separate adjustment buttons on the transmitter....I assumed these were how to set the trim, not by the actual control stick....what am I missing here?
I didnt mean to confuse you if I did. I was meaning by "left stick" that the buttons around/near the left stick would be the ones you would use for trim. I'll try and make a drawing and upload to explain....
My drawing may not look like your TX...but you should get the idea. The vertical buttons would be throttle trim. The horizontal, the rudder trim
Hope this helps
