RE: ESM BF-110C ZERSTORER 95
The Aerovate 20 turned out to be a sweet little engine after start and setup... After a few minutes of hand propping I could see the carb is not going to draw fuel, so I used a electric starter and the engine started soon after... when the throttle was moved up more then half the engine would die, I opend the hight needle 1/2 turn and this time after start, the engine would go into high gear with no problem, while running full throtle I opend the high another 1/8 turn before settling on that as a good needle location.
The second engine was identical, I had to open the high 5/8 more... The low was fine on both engine... I am turning 15x7 Master three blade props, I did not tack it but this thing is running sweet, they both transition from low to high effortlessly and sound great running side by side..
