RCU Forums - View Single Post - More Push Rod ?
Old 10-26-2012 | 07:28 PM
Charlie P.'s Avatar
Charlie P.
Default RE: More Push Rod ?
ORIGINAL: JPMacG
Reading through this thread made me curious about the amount of thermal expansion we really might encounter using a plastic push rod. I did some homework and came up with the following:
Assume the pushrod is 30 inches long (typical for a 40 sized plane)
Assume there is a 30 degree F increase in temperature
The CTE of plastic varies widely with the type of plastic. The lowest I found was 15 parts per million per degree F (for polyimide) and the highest was 110 ppm per deg F (for polypropylene).
Doing the arithmetic, the pushrod would grow in length about 0.1 inch for the high-CTE plastic and about 0.01 inch for the low-CTE plastic.
What he said. They may expand, but one or two trim clicks and it is forgotten. Not a big deal.
