RCU Forums - View Single Post - Pull Pull Elevator - your thoughts
Old 09-11-2003, 11:19 AM
cstevec
cstevec's Avatar
Default RE: Pull Pull Elevator - your thoughts
Like aerobob says, coated fishing leader line makes very good pull-pull cables. When you crimp 'em make sure you pass the wire through the crimp sleeve twice to eliminate the possibility of the cable somehow pulling free. For a cleaner install I slip a piece of heat shrink over the wire and after crimping the connection I shrink the heat shrink over the connection to make for a cleaner looking install.
Oh yeah, never use nylon clevises with those little eyelet rods (4-40 or 10-28) to attach your wires to control horns or servos. I learned that one the hard way.[:@]
