Pull pull setup ?
Setting up a pull pull rudder on a small electric Yak. AUW will be about 2lbs.
There is no turnbuckle supplied like on my bigger glow pull pull system. Looks like you just pull tight when crimping the ferrel?
Tried it and the crimp doesn't hold... Very light weight wire...
No luck searching for options?
Seems like you would need some adjustment even on such a lightweight setup?
Anyone know of a lightweight pull pull setup that's available ?
Steve
