RE: Need airfoil file
Blake,
You should be able to produce the polars by using X-Foil (MIT) and the info on Dr. Quabeck's website as to the program parameters.
I guess XFoil is at the core of Profili so you should also be able to regenerate the "Akro 0/12" foil using the latter.
David
