RE: Simjet 1700 glow plug
For some reason, I expected that you where using a Gaspar ECU. But if you are using the SimJet ECU, this problem can be a bad earth in the engine and sometimes it is the threaded ring that you screw the glowplug in to, that has come loose from the combustion chamber.
Hope you get it going
Best
Kim
