How Do You Debond CA Glue Is there a special trick?
I have used CA debonder by Jet and Ihave used debonder by Mercury. But Ihaven't had much luck with these. I have found that if you are patent and use a lot! It will eventually work. But my biggest problem is the fact that it seems like one needs to use a lot when not that much comes in a bottle. Are there any alternatives to using the expensive Debonder or Any methods that are more Efficient?
