RE: Failsafe Question
We are not familiar with a NAZA controller. With Futaba 2.4 GHz receivers, none of the servos will actually lose a signal when the system goes into failsafe. They go to predetermined positions. The 8-channel receiver allows you to set the failsafe position of every channel. If your multi-rotor system has its own failsafe system, then however you set the system to make it work would be correct.
