RE: NGH 38CC 4 stroke
I think you are mis-reading the saito manaul.
It says that the clearance must be within 0.03 and 0.10mm
In that position, adjust with the included gauge and
hexagonal wrench so the tappet gap may be set to
almost zero when the engine is in the compression
With a gauge in between the valve and tappet the gap may be set to almost zero.
Not without a feeler gauge....
But you are right that 0.10 is probably too much, as it is at the maximum of the reccomended gap.
I will adjust it to 0.03mm
