RCU Forums - View Single Post - FEJ Large Hawk
Old 12-09-2012 | 10:53 AM
Ali's Avatar
Ali
Default RE: FEJ Large Hawk
Starting with the ailerons. My kit differed from the instructions in that the servo boxes that the manual says have to be assembled and fitted by the user, were in fact pre fitted on this one. Not sure if this is the norm or not? I guess James can weigh in on that?
This photo clearly shows the honeycomb structure and the paint finish ( This is how it came out of the box) You can also see thew pre run wires for the wing tip lights. I suggested that the factory may look at the option of running servo wires during construction. This would make pulling the servos through much easier for the end user, or one could even solder on a servo plug/ socket and be done with it. Routing the cables through the wings was not the most pleasant of jobs.
