ORIGINAL: MKnutson
I just recieved my engine today.
It looks to be of decent quality, excellent compression too. The only problem is trying to get it started!
It doesn't want to run as good as it looks, and it needs a real muffler very bad. The carb won't pump fuel well enough to keep it running very good.
It sounds like it's laboring when it's running. It doesnt seem to be getting too hot at all when running.
Fuel ratio 25-1, premium fuel.
18-10 Mejlik.
Seems to need chokeing every time to start it, even hot.
I am going to check cam timing, ignition timing, & valve clearance.
Mine does not sound like the ones in the you tube videos.
So far, I'm a little disapointed in the way it runs. Can't put it on a plane like this, going to work with it though and get it figured out!
Mark
I will say I got the NGH 35Rear Exsaust. And I have always had issues with it hand starting. I just gave up, put a 4s lipo on my electric starter and Use the electric starter with the choke on and thro on mid unitll it burps. Then take the choke off and hit it with the starter and with in 2 sec its running. IT is actully faster to start with the starter than hand start my dle motor for the first time.
Good Luck Mike
