RE: Seagull Model Cessna 337 ARF
Still looking at servo's. Right now here is what I'm thinking, but open to suggestions...
Rudder - HS-85BB (x2)
Throttle - HS-311 (x2)
Ailerons, Flaps - HS-225BB (x4)
Elevator - HS-225MG (if it will fit in the center section)
Nose gear steering - HS-225MG
I'd like to have a little more torque on the elevator servo, but am probably going overkill (as I usually do). I have a Scat Kat twin with two K&B 40's that goes about 125 mph and a standard Futaba 3004 is all that I have on elevator. It works fine, so I'm sure the 225MG should be plenty. What are your thoughts on servos??? Was thinking about digital, but it's really not needed in this application, IMO.
I think we finally settled on the Magnum 52's for engines. They will be mounted on their sides and only require holes in the cowls for the rocker covers to stick out. He already has one on hand so we only need to pick up one more.
