Hi Michael.
Sometimes these things happen
The standoff problem is not a big problem.
Can you tell me how many degrees of ignition timing you used on the prototype engine you have running ?
In these pictures the piston is at TCD
and the timing is at 43 degrees BTDC
I made a timing mark on the prop hub, and case.
